Lochinvar noble Setting troubles
Hi am located in New Jersey , I need help getting my home this winter at a constant temperature of 72 degree. Last year I had so much trouble. Does anyone have an idea of what the setting would be when the outside temperature falls below 65 degrees ? I want to beable to keep my home at a constant temperature .
  • neilc
    neilc Member Posts: 3,152
    uh? set thermostat to 72 ?
    need lots more info,
    type of thermostat, heat source, other known issues ?
    post pictures of thermostat, heat source,
    are you new in this space? or what's changed sinse it was 72 last?
    known to beat dead horses
  • GroundUp
    GroundUp Member Posts: 2,502
    Installing a thermostat and setting it to 72 would be a good start. Factory WWSD is 68 on a Noble, and the lowest possible water temp I believe is 80, but that number is entirely dependent on your heat emitters.
  • flat_twin
    flat_twin Member Posts: 355
    edited September 2023
    Who set the parameters for space heating on your boiler? Can you share the current settings, type of emitters etc. Heat loss figure for your home is ?
