Quieting a loud bath exhaust fan.
New bathrrom with remote fan. Two ceiling vents Y into the remote fan input about 15 feet away, then out the side of the building it goes. Similar install at another location is whisper quiet. This install … very loud. The difference? The quiet one is flex ducted, the loud one is hard piped. Ceilings are closed. Do I have any options to quiet the roar?
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    edited September 2023
    Presumably there is access to the inline fan ? Could maybe play around there to figure out which of the 3 pipes is making a harmonic or if it's the fan itself (vibrating) ?
    EBEBRATT-Ed Member Posts: 20,172
    Maybe putting in a damper and closing it slightly would help
  • woobagooba
    woobagooba Member Posts: 186
    Here is my access. You can barely see the two 4" pipes coming into the fan, then the 6" pipe to the outside.
  • Dave Carpentier
    Looks like a treat to service lol. Looks like you cant get to the input side at all.
    Is it an air rushing/swooshing sound ? Whistle ? Howl ? Low pitched hum ?
    Can the fan speed be changed ?
  • woobagooba
    Loud low frequency whooshing sound. I will check the fan speed detail.
