Theories
Grallert
Grallert Member Posts: 969
Discovered while opening to clean one of the floats for a feeder valve. I have my theories. Anyone else?
  • ChrisJ
    ChrisJ Member Posts: 16,784
    You have a hypothesis....
  • JUGHNE
    JUGHNE Member Posts: 11,444
    Water hammer......was it located in the correct place?
    Rick Rolston
  • Grallert
    Right!
  • Grallert
    Could be. Thought I haven't had any hammer in the eight years I've been running there.
    Here's my th... hypothesis. Is this possible? It was a vacuum in the float. It's an old float, could have developed a very small leak. enough to allow a little water in. That water steamed and was then cooled enough to create a vacuum? Is that far fetched?
    H2OBandit603ttekushan_3
    Steamhead Member Posts: 17,861
    Possibly. Regardless, it needs a new float.
    Consulting
    GrallertRick Rolston
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,232
    Crushed via vacuum . Mad Dog 🐕
    ttekushan_3Rick Rolstonjamplumb
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,638
    Absolutely water hammer. Brings me back to my McDonnell Miller days.
    Retired and loving it.
    Grallert
  • ScottSecor
    ScottSecor Member Posts: 989
    I'm in for $100 on water hammer. Highly doubt it was vacuum that caused this.
  • DanHolohan
    I saw this a lot. The factory alway analyzed it as water hammer. Goes back many years. It really gets your attention. Such incredible power.
    Grallert
  • Grallert
    Pretty amazing. I'm wracking my memory to see if there was a time I might have heard something. But I'm not here all of the time and the boilers are not under any residential spaces or dormitory spaces so I'm not surprised it when unnoticed. Thank you all for the feel back.
  • JUGHNE
    Can you show us where it is attached to the boiler?
    I can easily see how an F&T would get hit, but perhaps this was boiler over fill with hammer inside the boiler?
    mattmia2 Member Posts: 13,184
    leaked, filled with steam, steam collapsed
    Montana14
  • Grallert
    This is my thought. but I'll go down a nd take a picture.
  • Grallert
  • retiredguy
    retiredguy Member Posts: 1,039
    edited August 2023
    This doesn't happen often but I have seen it happen on a multiple boiler job where an off boiler flooded and some novice blew that column down to lower the water level. The resulting water hammer can sometimes be extreme enough to collapse a float. I have seen instances on H B Smith cast iron sectional boilers where the water hammer cracked sections and once I was in the boiler room when the result was that the boiler lifted itself off the boiler's base. That day, I was scared and told everyone to leave the boiler room to make sure that no one caused another stupid problem. WOW, that sure is an old relic. Is it a Fitzgibbons?
    Grallertttekushan_3Long Beach Edjamplumb
  • Grallert
    edited August 2023
    Pacific Steel. There are two. Installed 1956 and 58.Pretty trouble free and well cared for. Thanks for this it answers a few questions.
    ttekushan_3
    Is that fraying stuff asbestos or canvas or canvas soaked in asbestos or what?
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,779
    I believe its water hammer I think that's why McDonnell Miller started recommending this way to pipe the blowdown to avoid the steam hitting the cooler water
    Ray Wohlfarth
    Boiler Lessons
    Grallert
  • Grallert
    no asbestos.
  • Montana14
    Montana14 Member Posts: 8
    i had this happen in a condensate tank with too much return steam. Float lost its seal. An attempt at a reseal it ended up in this condition.
    Long Beach Ed
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    Water hammer my industrial pipe supplier has three or four of those floats on the counter in that condition.
    cell # 413-841-6726
  • Grallert
    This will sit on my shelf as a reminder of the this that can happen.
    Charlie from wmass
