Adding radiant floor heat to addition
The first step is to get a heat load number for all the rooms you want to heat
Next is the design step, this tells you what temperature you need to send to the various rooms, tube spacing, flow rate, etc
It probably will require two temperatures so that panel would need some mods. Certainly some useable parts thereBob "hot rod" Rohr
Living the hydronic dream2 -
You're going to have neverending airlock problems with the upper loop(s) if you attempt to use this setup without an additional plate exchanger for the radiant. As hot rod said, the upper level would also likely require a higher water temp than the slab so aside from the circulator, you'd probably be time and money ahead starting over new if you want to do it properly. If you don't care about temp fluctuation, it's possible to reuse exactly what you have and simply run the same temp fluid through both levels as one zone. You'll still want a heat exchanger either way though, or you'll be chasing airlocks forever.2
Reflecting on radiators bec I wasn't really satisfied with doing staple up radiant in my previous house.
And now that I'm in my, way down-sized, hopefully last house, 1K+ sqft, single story, 16" thick boulder stone walls on slab. I'm storing radiators for installation, hopefully in the near future, and flipping a coin as to how to run the series-parallel piping, but staying out of the attic space. Cutting channels in the concrete doesn't sound like much fun, esp with possible future problems, and exposed down pipes from the attic leaves me with old time, tenement apartment pipes, ala The Honeymooners, or some sort of decorative covers. One way or another, the currently tiled floors will be redone in prefinished, 9mm, floating t&g. I've also considered 1" sleepers to run radiant.
Any & all suggestions welcome
The challenge with retrofitting floor radiant over an old slab is the insulation detail.mvickers said:Reflecting on radiators bec I wasn't really satisfied with doing staple up radiant in my previous house.
Ideally you want 2" below a new slab or any system really.
There are foam panels like the Roth system that work well, you need to accommodate the 1/2" plus the final flooring height. But even with a 3/4" floor build up, that can interfere with doors, base trim, exterior entries, and stairs, etc. And not much R value from the current slab either.
Radiant ceilings are another nice option, the same radiant "feel" just from above.Bob "hot rod" Rohr
Living the hydronic dream1 -
You're on the right track. Radiant can't be matched! When you try to build anything around a used part you're DETERMINED to USE!!!, you often start to do strange things to accommodate this one USED item that costs a few hundred dollars.
Listen to the boys...do your load calls and follow from there. Don't base the whole job on trying to use that manifold. Ask me how I know. Mad Dog 🐕
You can modify anything,but that setup is build where it is actually easily modified for your purposes. I would suggest adding a drain to both the supply and return manifolds when you do modify them to ensure easy purging and draining in the future.Experienced Boiler Mechanic In Summit County, Colorado.1
