If our community has helped you, please consider making a contribution to support this website.  Thanks!
Hot water recirc systems appears installed wrong but works
                    tset
                    Member Posts: 6
                    My new-to-me instant hot water system appears to have a Goulds recirc pump which pulls from two dedicated return lines that pull from a master bath sink and the kitchen sink. The return lines attach to recirc pump at the water heater cold water input.
I can't see any other components to the instant hot water system. House is slab with plumbing in the slab.
All fixtures in the house have quick hot water.
But, both sinks with the dedicated return lines have the return lines tee'd into the cold side!
Anyone know what is going on here?
Regards, TS
Regards, TS
            Sounds right, there may be a check valve on the cold water inlet?
 Some method to control the pump?
 Pictures showing all at the tank and pump would be good.0
            Hmm, the pump has a variable speed setting. But with no valves connecting hot to the dedicated return at the fixtures, how does recirculating the cold water accomplish anything? (Yet it apparently does.) Will try to get pix.0
            Not sure what you mean by return lines tee into cold? At the hw tank?
 that is where the returns would tee in to push hot out the top of the tank and down to the fixturesBob "hot rod" Rohr
 Living the hydronic dream0
            Hi, A sketch of the plumbing would help if photos can't do it. Is your cold water still cold, or does it get warm when the pump runs?
 Yours, Larry0
            yes, that's my point, the dedicated return lines tee into the cold lines at two of the distant sinks. There appears to be no way for the hot circuits to flow back to the hw tank. I cannot find/see any temperature controlled or check valves anywhere at the fixtures. But they must be there? Hidden under sink cabinet floor? I understand that electricians and plumbers do not "hide" junctions and active devices?
            I can't see anything in the kitchen picture but going by your bathroom picture and description I have no idea how that could do anything as far as hot water recirculation.
 Seems like it's circulating your cold water to me.......
 Which makes me think it doesn't work.
 I'm not sure if it matters but...........do you have electronic faucets by any chance?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            Those circulators tend to get air locked when mounted up high on the tank like that
 The installation manual cautions against having it at the top if the tank
 Id like to see an air vent where the expansion tank is connected also.Bob "hot rod" Rohr
            There doesn't need to be a valve, just a tee that connects to the recirculaiton line.0
            Do you have a basement, look under those sinks for a tee cut into the hot lines.0
            Hi, You might get some useful clues by keeping the pump off overnight and then have someone turn it on while you run around and feel the temperatures of the pipes and see if, or what gets hot, and when. That might help all of us to make sense of things.
 Yours, Larry0
            Your connection at the hot line is most likely in the floor or in the wall since those taps you are seeing are outside hose bibs. The only 2 issues i see with your recirc connections on the water heater itself are that: 1. The pump is orientated horizontally which will effect the flow rate and life span of the pump, and less importantly: 2. There is no way to isolate and purge your recirc line of air from the room itself. I wouldn't be too concerned about either, but might be a thing to fix when it comes time to replace the pump down the road.Experienced Boiler Mechanic In Summit County, Colorado.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
