Munchkin High Efficiency Heater w/ 925 Controller - Question - Heat not turning on
Schuhwerk
Member Posts: 1
Hello all, my heater is not kicking on, I turned it on from the thermostat a couple hours ago and we have baseboard heaters throughout the house, none of them are getting warm over the past couple hours.
I too a look at the display and it had a 71 on it when I looked at it an hour ago, it dropped to a 70 then now a 69, not sure what significance that has , as I couldn't find anything on line.
Any suggestions on what to test or reset?
Thanks all
Thanks all
did the boiler start-up when you adjusted the temp at the thermostat?0
Why don't you just go into the programing and look at the data setup? You do have the installation manual, right?0
I think he is gone. Probably something simple he found. It would be nice to know, as we sit here with the engine idling.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
