50 Gallon Indirect Hot Water Tank Manufacture Recommendations?
PilotPat24
Member Posts: 106
Hello,
Does anyone have a preference or recommendation for a 50 Gallon Indirect Hot Water Tank?
Thanks,
Pat
Thanks,
Pat
Lochinvar SIT050 stainless tank or Viessmann stainless
IMHO0 -
If you go with stainless make sure the chlorides in your water are less than the manufacturer spec.0
Thanks for the feedback guys. How do you go about getting your water tested for chloride levels? For what it's worth, below is the whole house water filter I have on the house.mattmia2 said:If you go with stainless make sure the chlorides in your water are less than the manufacturer spec.
https://supplyhouse.com/3M-Aqua-Pure-5621102-Aqua-Pure-AP903-900-Series-High-Flow-SQC-Whole-House-Filtration-System?utm_source=google_ad&utm_medium=shopping_neutral&utm_campaign=Shopping_Neutral_MPLTV&gclid=Cj0KCQjw7aqkBhDPARIsAKGa0oIzutT7rqgccEc91sLaftvvi7OYTLF6ouSPhxIVOXmi0yQWpbKVPaAaAusFEALw_wcB
Pat
Thanks! I actually called my water supplier and they are going to come by next week to test the water. I will update you with the results.Larry Weingarten said:Hi, If you are on a municipal system, they will have a water quality report for you. Probably online.
Yours, Larry
Pat0 -
The welds are often blamed for stainless tank failure when in fact the chlorides attack the welds more so than the stainless itself. Dave Davis of HTP explained that issue many years ago when I visited HTP factory. Back early in the SuperStor days
His dad had a welding division of HTP, used to be in the other side of the HTP building, so he knew welding metallurgy fairly well. The metal properties change at the welds, so different shield gases, wire composition, pickling after the weld, etc. have been tried.
George at HeatFlo knows stainless fabrication well, if you get a chance to chat with him.
That is one reason you see all the different alloys of stainless being used over the years 304, 316, 409, 316AL and Ti stabilized, etc. Trying to find a stainless the handles all the water treatment chemicals, welds easily, handles thermal expansion...
And the water treatment chemicals have changed over the years. Chloramines in place of chlorine for example. Peroxide, Iodine, etc.
One brand out of Canada used to use a different stainless for the coil and tank.Bob "hot rod" Rohr
Living the hydronic dream1
- 123 Chimneys & Flues
