CO2/O2
mikeGlosta
Member Posts: 5
in Oil Heating
My technician's tag reading. after tune-up, reads CO2/O2 5.5%
Can you explain what this number means, is it where it should be, or needs improvement?
Thanks
Thanks
First off I'm not a pro. The 5.5% is the percent oxygen in the flue gas. Take a look at this link for a quick explanation: https://www.beckettcorp.com/bulletins/burners/general/combustion-testing-oxygen-or-carbon-dioxide/0
Can't say for sure but that looks (the 5.5%) like an 02#. Perfect co2 on oil is about 15%. But you can't achieve that. You usually adjust for 11-12% with a modern burner. You total of Co2 and O2 add up to the perfect # so in you case 15-5.5o2= 9.5 Co2.
Numbers for gas or other fuels are a little different2
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
