best book on radiant heat and design
mikedo
Member Posts: 301
got involved in a radiant heating system i shouldn't have. supply house that claims to be a heating design specialist is clueless. they gave piping diagrams for in slab work but want nothing to do with boiler piping and control systems. im wondering if there is a newer book than dans im reading it now but its 25 years old and some information seems dated. thanks mike. if anyone knows someone willing to consult on the project let me know obviously would be willing to compensate them for there time
1
What part of the country are you in?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
A few steps involved, the first being the room by room heat load to assure radiant is a good match.
Floor coverings?
Type of heat source
Tube layout, piping and control options
The Idronics issues cover most, the tubing manufacturers will usually do a layout and design for you that should be accurate.
https://idronics.caleffi.com/Bob "hot rod" Rohr
Living the hydronic dream2 -
Dan's Books are great for a primer, Siggys, then Caleffi ls great and beautiful to look at too! Wirsbo/Uponor intel is great. Where in America 🇺🇸 are you, Mike? Canada ? Mexico? I'm sure one of us is not too far away from ya. Mad Dog 🐕0
connecticut the supply house used uponor program for the piping layout so hopefully that is ok. its already installed. but that seems to be the extent of their knowledge on radiant heat. called about piping and they said thats on us. its 3 zones and was set up for thermostats thinking of just piping it like regular heating zones there are senors for the slab temperature0
Radiant Precision by John Siegenthalergwgillplumbingandheating.com
watched some videos on uponor website and called tech support.tech support was great spent a while helping me with questions the person was very knowledgeable0
More than everything you every wanted to know, you can find on the internet. I suspect everyone publishing these sites are inspired authors that haven't gotten around to writing a book.0
And here's a great publication - free - on zoning:
https://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2020/01/FH-Z100B-BG-Zoning-Made-Easy-2.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
