Replacment for ESBE VM-62 4-way mixing valve
joecurran
Member Posts: 1
I have a 20 year old Buderus boiler with a Logano 2109 controller. I am changing the controller with a newer model 2107. I also need to replace the mixing valve. Currently have ESBE VM-62 What is the correct replacement valve for this situation ?
The brass valve, or the actuator?
I think ESBE is connected with Danfoss now, the valves should be the same as the current ones. The actuator may be a private label to Buderus?Bob "hot rod" Rohr
Is it 3-way or 4-way and what pipe size? Danfoss bought ESBE. For 1/2-2" Danfoss 193B series and
2-1/2 - 4" it's the 065B series. Actuators for 1/2 - 2" are the 193B series and for 2-1/2 - 4" they are
065F series.0
- 50 Industry Classes
