Weil McLain HE-5 Series 3
Thank you. I did open it up and it looks great inside, no signs of leakage between the sections or anything and the makeup water is off. Fan is quiet and I do have a spare that came with the property. The maintenance guy who takes care of the property was a boiler operator at the local hospital in a past life and takes good care of this system, but I'm sure there is only so much that can be done. 39 years seems to be stretching the limits from what I've been reading?kcopp said:Thats the right timeframe.
The fan and the boiler control could be failures.
That being said an inspection of the boiler from below may give you some clues to a leak. Hard to say for sure but they are pretty decent units.
If you have space, and do a little repiping, I would install a second unit and leave the old one tied into the system as a back up. If piped properly with primary/secondary piping and/or with check valves, the off unit will stay cold while the other unit is running, so you maintain full efficiency of each unit. You could also install a unit with just enough capacity for your typical winter day weather so you max out it's efficiency, and then bring the larger unit online during the few days of extreme weather a year.To learn more about this professional, click here to visit their ad in Find A Contractor.1
Good thinking! I was considering the idea of putting an electric boiler in series for the same reason, as the dual-fuel rate at this property is only $.058/kWh. I've done a few systems like this, recently one in another apartment building, and they are working out great. There is only 100A service currently to the mechanical room so I'm waiting for a sparky to get back to me on the cost of bringing 200A in from the pole. I hadn't considered adding in another gas boiler like you suggest- maybe even a mod/con at that, to maximize efficiency on warmer days. Now you got my wheels turning!The Steam Whisperer said:If you have space, and do a little repiping, I would install a second unit and leave the old one tied into the system as a back up. If piped properly with primary/secondary piping and/or with check valves, the off unit will stay cold while the other unit is running, so you maintain full efficiency of each unit. You could also install a unit with just enough capacity for your typical winter day weather so you max out it's efficiency, and then bring the larger unit online during the few days of extreme weather a year.
If you baseload with a smaller boiler, a modcon is probably not worth the cost and trouble. You've already probably picked up most of the efficiency gain with a small baseload boiler since it will be running at peak efficiency. Most large single boilers that we replace with simple stage fired atmospherics cut fuel usage about 30% and as high as 70%. Of course the existing boilers are usually oversized.GroundUp said:
- 50 Industry Classes
