New Laars FT Series Combi Boiler only has zc location terminal shared with system pump L.
TCTOPPS
Member Posts: 53
New Laars FT Series Combi Tankless Boiler and it only has zc location terminal shared with the system pump Line terminal location. I am trying to activate a Taco SR503-4. I have removed the jumper from the board at zc and zr and ran a line from zc on the relay to zc on the boiler. I have removed the system pump hotline. Just thought I need to reconnect but am not sure. There is no zr location as a terminal location. What to do? Thanks
- 50 Industry Classes
