Belt change on whole house fan
Servicewiz_3
Servicewiz_3 Member Posts: 69
I am working on a Crystal-Aire,
Vent - A- Pack whole house fan. I cannot see how to replace the belt!
Please help!!
  • STEVEusaPA
    Got a picture?
    mattmia2MaxMercy
  • unclejohn
    unclejohn Member Posts: 1,833
    Need some pictures. Belt adjustment is normally fairly easy. Get some light and look it over good. Loosen up motor mounting bolts and slide is how most work.
    EdTheHeaterMan Member Posts: 11,782
    I'm sure there is a way to replace the fan belt. I know this because that fan belt was not manufactured at the same location as the fan blades or the fan motor, or even the pulleys for that matter. But they were all put together at the same place. I bet if you remove enough nuts, bolts and screws, you will be able to get a new belt on that fan assembly
