Oventrop Source
I need some Oventrop lockshield radiator valves, 1/2" copper compression x MIP angle pattern. My supplier is out of them. Does anyone have a source they can share?
    Alan (California Radiant) Forbes Member Posts: 4,526
    edited April 2023
    It may not be an Oventrop. This is the valve I'm looking for.
  • GGross
    GGross Member Posts: 1,589
    ah nevermind those ones were threaded style i shared
  • Derheatmeister
    Derheatmeister Member Posts: 1,658
    Check with Low Energy systems in Denver Colorado
    1 800 873 3507 Talk to Seth.
  • Grallert
    Grallert Member Posts: 975
    Or Hydronic Alternatives
    PC7060Alan (California Radiant) Forbes
    hot_rod Member Posts: 25,454
    Are you looking for an exact replacement to fit those compression nuts? If so, usually there is a name or logo forged into the body to identify.
    If you can start from scratch, and the radiator is BSP or NPT?
  • JDHW
    JDHW Member Posts: 107
    If the threads are BSP have a look at Danfos.
    John
    edited April 2023
    Here are some better pictures of the valve. It's an American made Runtal radiator, so NPT.
    Looks like the letter OV on one side?
    Did you try Oventrop directly at the CT office? Looks like Ferguson carries some Oventrop
    edited April 2023
    Yes, I called them. When I ask for a copper compression inlet, they gave me two part numbers. One is for a valve with a FIP inlet and they other is for compression fittings, but no way to put them together.
  • dko
    dko Member Posts: 669
    Runtal uses Oventrop for all their valves, but they do not sell that compression version - only MNPT x FNPT.
    The compression fittings you posted are technically for these Multiflex units in the US market.
    Oventrop does not sell the 1/2 NPT x 1/2 Compression valve as a SKU in the USA. If it was purchased in the USA, it was imported by or for another manufacturer. For example Mestek has Oventrop build them exclusive valves for their beacon morris panels (I checked, no compression).
    A way you can make that valve from only US sources is to buy 2 valves and that fitting.
    But if you have a supplier that can communicate with Oventrop/representative directly, they can probably make it up for you. I can ask on Monday if you still need.
  • GGross
    Runtal should have the angle valves in stock. I am sat here with the (probably) exact compression fittings you need but no valve for them. I sent a set of angle valves that was shipped in error back to Runtal about 2 weeks ago, maybe they still have them🤣 !
    Are you looking for the exact same replacement valve? Leaving the fittings inn place, swapping the angle valve?
    What is wrong with that one?
    Sounds like you want 3/4 conical inlet, chose the tailpiece you want, and NPT or BSP outlet.
