TEKMAR 563 Programming
jalagna
Member Posts: 43
Hello, I was wondering if you are able to program a TEKMAR 563 to run both a heat pump and hot water rad simultaneously instead of a primary and secondary. Thank you in advance!
Probably. Need more info, like what other components are on your system, but you can start with the manual:
https://www.watts.com/dfsmedia/0533dbba17714b1ab581ab07a4cbb521/81778-source/563-dl-01
Living room zone on my first floor, I have a heat pump and a few hot water sun rads. I set the stat to use the heat pump as primary bc it also runs a register I have in the basement. The problem is that the living room has a slight chill, the heat pump makes temp on the stat and shuts to soon, I feel the radiators will maintain heat much better.0
