Small issue with site on closed discussions.
mR_Slug
mR_Slug Member Posts: 13
When i do a search for a topic, as seen in the image, any closed topic has "No formatter is installed for the format not-found" in the description instead of a description. Looks like an error from the forum software.
Erin Holohan Haskell
    Steamhead Member Posts: 18,474
    Consulting
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,708
    Erin is away for a few days. She’ll answer when she can. Thanks for your patience.
    Retired and loving it.
    Erin Holohan HaskellCLamb
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    Thanks @mR_Slug. I believe this is happening because they are older posts that date back to 2005. We've redesigned the site a few times since then and while we were able to bring older content with us, it might not fully cooperate with this newer software. Thanks.
    President
    HeatingHelp.com
    PC7060
  • mR_Slug
    Thanks for looking in to it. You have a real personal touch here.
    Quick follow up question @DanHolohan. When you were at Starbuck, how did you walk away without picking up some Unique valves and other stuff?
  • DanHolohan
    They weren’t offered. I respected that.
