Radiator Valve
I am trying to locate this type of Radiator Valve . With this valve , both the supply and return can be on one side of the radiator (vs the supply on one end and the return on the other end).
Attached pictures , thank-you.
Not sure they are still available. @hot_rod might know.
I'm not sure what goes on inside that valve?
There are conversion valves like this for radiators that allow dual pipe and the ability to add a thermoststic head. A number of different connection varaitions.
I've test one out in my shop, they work well.
If you want something to match up with the holes in the floor, that might be a tougher assignment.
Needing just one?
Honeywell valve0
Hot Rod Knew
- 50 Industry Classes
