Radiator identification
fararelliott
Member Posts: 7
Greetings, all - I wonder if my older and better steam heat pals can guide me in identifying a radiator in the apartment we are moving into. I haven't found a maker's mark on it, and I am not even sure what kind of radiator to call it, which is really hindering my research. The tubes seem to loop like a sea monster rather than line up in rows the usual way. There is also a big grate thing that sits on top.
Here's the grate.
If there's a name on it, you'll find it on the base. If there is no name it's probably a Nason. Go here:
https://heatinghelp.com/heating-museum/ratings-for-gold-nason-bundy-and-reed-radiators/
Where is this located?All Steamed Up, Inc.
Consulting2 -
thanks, all. It is in DC and looks older than our 1910 building, but I know so little about radiator history that I am grateful for the help.0
Also, what is the reasoning behind the tubes going the other way than most radiators?0
It was a cheaper way to make radiators then casting.. . Yours was built in a small shop with a small foundry . Just a guess .
That is something else!
I don't see any leaks , nasty looking
- 119 Chimneys & Flues
- 76 Pipe Deterioration
