Looking for Modine or similar Convectors
guzzinerd
Member Posts: 423
Looking to replace 4 missing convectors in our old building. Ours are by Modine but will consider similar options.
Thanks
Thanks
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Beacon-Morris makes some nice ones- not the same look though, but AFAIK no one is making that Modine design. Go here:
https://www.beacon-morris.com/residential-and-commercial-convectorAll Steamed Up, Inc.
Consulting1 -
Thanks I'll check them out ... Actually, what was put in place of the Modines are pretty much what beacon Morris sells. They only work when the steam is on and don't put out near as much heat as the old Modines which are mostly cast iron.
This is a last ditch effort to find something as heavy as the Modines before getting free-standing rads.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Cast-iron? Look at these- they combine radiant and convective, like your Modines.....................
https://ocsind.com/products/cast-ray-radiant-convection-radiator/All Steamed Up, Inc.
Consulting0 -
Now we're talking. Thanks!Steamhead said:Cast-iron? Look at these- they combine radiant and convective, like your Modines..................... https://ocsind.com/products/cast-ray-radiant-convection-radiator/Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
- 123 Chimneys & Flues
