Water Detection/Shutoff Devices
jdbs3
Member Posts: 34
in Gas Heating
Reference attached picture:
Mechanicals room with boiler is in attic. Water shut-off valve for house is in crawl space, 3 floors down.
If I am not home and either the DHW tank fails, or the Bosch boiler fails, it would be good to have some way to stop the water from continuously running until I return.
What are my alternatives for both recognizing there is a water leak, but more importantly to then shut off the water supply?
https://pcmag.com/picks/the-best-smart-water-leak-detectors
has lots of choices, some just detection, others a Smart Water Monitor and Shutoff.
What do folks in the business recommend as the best product for a homeowner.
Quality of product is most important, followed by cost.
Thanks!
Thanks!
