It's easy for you guys but
guzzinerd
Member Posts: 451
Pretty happy i managed to add a trap under one of the floor board units that were added without traps.
Used a stick to brace the pipe so i could wrench upwards, then cut, pb blaster and map gas the old pipe came out and trap in.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
1
Looks good. How does it work?All Steamed Up, Inc.
Consulting1 -
@SNS
I agree but in some cases too much hammer can cause a leak in an adjacent joint. I like to cut the fitting part way with a grinder then drive and old screwdriver in it to crack it less pounding that way.
And some don't realize how important the back up hammer is1 -
Yesterday was warm enough to install the final 4 traps under the trapless baseboard heaters. Ended up being far easier to just cut, thread and screw them in rather trying to remove anything. (I did wrap the pipes with 1" fiberglass)
I'll be installing the final 9 trap rebuild kits next week, can't wait to see how much less gas this thing is going to use. Almost sorry spring is around the corner.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Nice job, however, don't insulate the returns. They don't give off much heat most of the year and if you end up with a bad trap, the piping can help cool the condensate so its doesn't destroy nearby traps. This is especially the case if you orifice the supplies.To learn more about this professional, click here to visit their ad in Find A Contractor.2
I thought I was supposed to wrap the returns?? I've spent so many hours and 30 rolls getting them all wrapped.
I know there's probably a few variables but how would it take, more or less, for a new trap to be ruined by a neighboring bad one? I've been renewing them one by one during the day and still have a few to goBryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Don't worry..leave it not really going to hurt anything either way. Mad Dog2
- 50 Industry Classes
