Combustion vibration
I have weilmclain 97+ 110 that is 6yrs old that is sparaticly making a vibration noise,lasts a couple minutes, don't get any faults or shuts boiler down, heat exchanger cleaned last March, still getting noise
  • HomerJSmith
    HomerJSmith Member Posts: 2,775
    You need to provide more information. Possibly, posting the noise.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Is the noise coming from the blower or combustion ?
  • bburd
    bburd Member Posts: 1,303
    Oil or gas fuel? What type of burner? Pictures?
    Bburd
  • MaxMercy
    MaxMercy Member Posts: 601
    That's often like trying to describe a squeak in your car.
    FWIW, I've seen circulators make noise that travels through the whole system making it hard to find. A small section of rubber hose used like a crude stethescope can often help find noises. While it's acting up, put the hose on the circulator(s), burner motor,etc.
    MikeAmann
  • SuperTech
    SuperTech Member Posts: 2,661
    This is a fire tube condensing boiler. Typically the noise is from the combustion not being set correctly with a digital combustion analyzer or in some cases the gas line being undersized. Nothing we can do to help you with a combustion issue but if you post pictures of the boiler and piping we can see if the gas line is a possible problem.
  • HomerJSmith
    Nat gas or LP? A mechanic's stethoscope that you can get at an auto parts store would help pinpoint the noise. Any valves not fully open?
