Switch lugs for Heat Timer EPU-CH
eappleton
Member Posts: 111
Hi all,
Does anyone know where to buy switch lugs for the Heat Timer EPU-CH? It's like to get the #2 morning pick-up lug.
We're having some chilly mornings while we wait for the building to catch up to the day setting.
Thanks,
Eric
Thanks,
Eric
Single-pipe steam | 24 apartment, self-managed coop | Federal FST-40 Scotch Marine boiler | Carlin 701CRD burner | Heat Timer EPU-CH | Honeywell pressuretrols | Heating oil #2 (20% bio)
Can you take a picture of the inside of the Heatimer box?
Temperature setbacks can cause problems in various areas-why not set it at an intermediate temperature, and leave it. Playing catch-up in the morning will burn up the fuel you saved during the night, if not more. Even if your main venting is working, but not of adequate capacity, there will be imbalance in various areas during that time.—NBC0 -
Just came across this thread after doing a Google search and thus registered for the site. Yeah, we could use the #2 "MPU" as well. I've lived in this self-managed coop 12 years and never realized it was supposed to come with one until today. I suspect someone several years ago unscrewed it too much while trying to adjust it and it fell into the sump just below it or bounced somewhere on the floor.0
- 117 Geothermal
