Connections on tankless coil
zepfan
Member Posts: 397
I was looking for recommendations on the preferred fittings to use on a tankless coil that is installed in a weil mclain oil fired boiler. The home that has the coil, and boiler is on a well so I don't know if the well water is contributing to the corrosion that is building up on the outer surface of the coil. From what I can tell the FPT connections on the coil have a copper lining, or they are entirely copper. Currently there are stainless nipples directly installed on the heater's outlet, and then switches over to copper piping. I didn't know if it was better to use brass fitting in a different type of sealer, such as leak lock or expando. It seems the stainless steel is having a hard time sealing, or the FPT fittings on the heater's outlet have an issue with the threads. Any suggestions would be much appreciated. Thanks to all
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
