What To Do If You Don't Have a C Wire For Your Thermostat
HeatingHelp
Administrator Posts: 722
The common wire is the neutral wire from the 24V transformer that provides the power that WiFi thermostats require in order for their features to work. Most existing homes do not have a C wire since non-connected thermostats don’t require them.
Pull a new cable with more than two conductors. FastStat Common Maker works too.0
Put in Batteries0
- 50 Industry Classes
