vitodens100-w B1HE
smithwd
Member Posts: 2
in Gas Heating
no tag with the wifi connection info on the unit....how do i get it connected
Have you tried contacting your Viessmann rep with the model# and serial# They're usually very helpful
Take the front control off the boiler (it came in a separate box in the boiler box), on the backside of that there is a QR code label with a little wifi symbol. This is the correct tag and should be stuck on the cabinet at install0
