vitodens100-w B1HE
smithwd
smithwd Member Posts: 2
no tag with the wifi connection info on the unit....how do i get it connected
  • Grallert
    Grallert Member Posts: 1,117
    Have you tried contacting your Viessmann rep with the model# and serial# They're usually very helpful
  • GGross
    GGross Member Posts: 1,895
    Take the front control off the boiler (it came in a separate box in the boiler box), on the backside of that there is a QR code label with a little wifi symbol. This is the correct tag and should be stuck on the cabinet at install
