Should I add a Wye filter to my radiator system while I have the chance?
eclecticmn
Member Posts: 129
Part of my system is valved off with 1 inch galvanized pipe, to go to pex.
I considered adding some treatment chemicals in the spring but was warned that lots of crap may come lose. I have to drain my system this summer.
Should I add a filter and what kind and pore size?
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
Something like this would be perfect for you:
https://www.supplyhouse.com/Caleffi-546306AM-1-NPT-5463-Series-DIRTMAG-Dirt-Separator-with-Magnet
Size and connection type will vary depending on your situation.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
YES
