I need to buy 9 radiators
Risi
Member Posts: 1
IS anyone selling in CT?
Size, style, water or steam?
Check in the scrap yards and have them air test the units to make sure they are sound or you could get new stuff
https://ocsind.com/
732-751-1560
Rich McGrath 732-581-38330 -
Careful of used radiators. Steam radiators may not work on a hot water system. Water radiators will sork on both. I believe Burnham sill sells radiators. https://www.usboiler.net/product/slenderized-radiator.html. The more artistic ones suggested by @Rich_49 may be more expensive. What is you project? High Style or economy replacement? Used rads are repurposed all the time at low cost.
There’s some on Craigslist. They look like good ones for water.0
Rich did not suggest anything except a manufacturer of all types of radiators and convectors . Who needs artistic when you wanna be warm ?EdTheHeaterMan said:Careful of used radiators. Steam radiators may not work on a hot water system. Water radiators will sork on both. I believe Burnham sill sells radiators. https://www.usboiler.net/product/slenderized-radiator.html. The more artistic ones suggested by @Rich_49 may be more expensive. What is you project? High Style or economy replacement? Used rads are repurposed all the time at low cost.
732-751-1560
I’m up the road 01060
i have around 60 or so radiators tucked in the walk out basement. Mostly Tube style and some ornate columns.
$100 to $400 each1
