Rinnai heater
dkelley
Member Posts: 1
Type your messageI have a Rinnai 1001FA/VA-P. I need a new fan motor as the current one is squealing like a bearing is going out. I had someone look at it, clean it and then told me I would need a new heater as the motor is unavailable. I wanted to reach out to find if was indeed true. I know it is an old unit but has been so reliable. Thank you, Dean
Does it look like this? A pic of the fan would help. I have lubricated fans with high quality turbine oil. https://www.swansond.com/storefrontCommerce/itemDetail.do?item-id=1516&order-quantity=1&item-index=0&customer-item=431F-1500-2&order-uom=EA&warehouse-id=1&item-number=431F-1500-2#
Rinnai at 800 621-9419?0
