Taco Flocheck Issues
Rizz861
Rizz861 Member Posts: 64
Hello,
I was wondering if a Taco 221 Flocheck could be the source of a zone not heating. The basics: tstat good, circulator on and is also new but return isn’t coming back hot. All other Flochecks to other zones look good but this thing looks crusted as hell. If you look at it wrong it looks like it will start spraying. Pumps are on returns and Flochecks are on the supplies. What’s  interesting is when I try to fast purge the zone with all others isolated, the pressure climbs to the point where I have to stop because of the relief valve. I’ve never had this happen before. Usually I can throttle the fast purge to not blow the relief, but this zone I can’t. It’s almost like the check is stuck partially closed or something. I don’t believe there are any restrictions and this zone doesn’t have a run subject to freezing (we have had mild temperatures as of late anyways). Do these things ever fail partially closed? Also, the knob on the top, it’s my understanding it make it a check or bypasses it. If I go out CCW all the way, is it a check at that point? If I go in CW all the way, is it bypassed? This particular check looks like a turn with some channel locks could be a break. Any ideas?
    hot_rod Member Posts: 27,769
    It’s just a chunk of steel at the end of the stem. CCW should lift it up, or the flow from the circ
    Remove the top, maybe it is stuck to the bottom somehow
    Rizz861
    EBEBRATT-Ed Member Posts: 20,431
    Sounds like the fc is stuck. CCw should be open and CW normal operation.
    Maybe a couple of gentel raps with a hammer will unstick it but it likely needs replacing
  • Rizz861
    @EBEBRATT-Ed So when you say CW normal operation that is as in it is a check at that point and CCW open as in check is bypassed correct? So this was a job someone else was doing and got stuck on and they called me. I’d like to know in the future how to get it right the first time. So troubleshooting a bad tstat, circulator, or relay cube on taco controller is pretty straight forward. If I see this again, I would think the fact that I couldn’t bypass the water feed and fast purge without coming close to setting relief off would be a good indicator the Flocheck is stuck, would you say so too? My go to for checking pumps has been to check power at circulator and if return isn’t coming back hot it’s no good. This obviously puts a wrench in that. I’m thinking I should check amp draw for an accurate diagnosis from now on. Would this be the most accurate method?
    What your doing is ok. The return should get hot if the system is not air bound and the pump is working.
    As far as am draw goes it would be lower with a stuck flow check and go up when it's moving water but with small amp draw pumps it is hard to tell.
    Rizz861
    A voltmeter or a spin-d-cator is a good quick first step. Amp meter is next. But a stuck impeller will also show a current draw.
    Some Grundfos and Wilo have a screw in the back that can be removed to observe the shaft spinning.
    However it could still have a broken shaft at the impeller.
    At some point you remove the bolts holding the motor into the body to confirm it spins freely when powered in your hand! Make sure nothing in the volute could cause it not to spin.
    Usually if the pump motor is scalding hot the rotor is locked and you have an 80 watt heater😳
    Rizz861
  • Joe Mattiello
    Joe Mattiello Member Posts: 752
    You can replace the working parts of check valve.
    sounds like it is stuck. Instructions are available at www.tacocomfort.com replace parts are listed too.
    call Taco at 401-942-8000 for tech support
    Joe Mattiello
    Taco Comfort Solutions
  • spudtu
    spudtu Member Posts: 7
    That is an excellent description, Ed. I've been trying to understand these valves and this is the first time I think I got it!
    My dad put a paintbrush in my hand when I was 4. I've been makin a mess ever since. Now I'm getting good at it!
    MikeAmann
    It is a weighted check valve that has provisions for manual opening.
  • spudtu
    Ok, you guys gave me enough confidence to turn that little thumbscrew on my Taco Flochek valve (on the supply side). I'm pretty sure the circ pump on the return is shot, and I was just hoping for some convection flow so pipes don't freeze before I can get a new pump in there. But with boiler running, the supply pipe was barely lukewarm on the downstream side of the FC. And the thumbscrew was stuck/frozen even when I put pliers on it. I didn't want to force it and snap the stem or something. So I wirebrushed the visible threads, soaked it with WD-40 and waited a couple days. Went back this morning and put the pliers on it, turned strong but prayed, and it finally turned. And best of all, the pipes are good and hot all the way around back to the return side! Thanks for the education!
  • GW
    GW Member Posts: 5,184
    I don’t see them sticking closed often; can’t even think of the last time- that’s a rare one. In wonder if oxygen is somehow getting into the system
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • spudtu
    Yeah, I wondered that, too. I thought maybe the pump was air-bound. It's quite possible, because I haven't ever been able to bleed the radiators - old coin bleeders that don't want to budge even with pliers, and I don't want to force them. But maybe I have more than one problem. The first time I fired up the heat this year, I got hot radiators. Then the next day I didn't.
    The pump it has 120v when the tstat is calling for heat. I took the cartridge off the pump body, disconnected the power leads and put separate 120v on the pump wires. The impeller did not spin, even though it spins freely by hand. Also checked the capacitor while I had everything open. Put it all back together, ran the drain near the pump for a while, turned that FC thumbscrew, and started getting hot pipes downstream of the FC. If you say you hardly ever see a stuck FC, then I'm still wondering, too.
    I also have another zone for the basement, and I think the pump went bad on that zone, too, last year. Radiator pipes burst in a poorly insulated spot. It was late in the winter and I never tracked down the problem. Funny thing is, yesterday I only turned the thumbscrew on the FC for the upstairs (the first zone) and then started getting hot pipes on the basement zone, too. Maybe draining that one drain valve got air out of both zones?
  • spudtu
    Thinking this through again, is it possible the upstairs zone FC was not stuck, but simply not allowing convection flow in the pipes, as intended by design? If the pump is not running, then the FC would not allow convection flow because it would be closed. But now that I opened it manually, convection flow can happen, even without pump running?
    Still doesn't explain why I'm getting convection flow in the basement zone when I was not before.
    edited November 2023
    @spudtu
    Flow checks were made to not allow water circulation unless the circulator is running. They prevent gravity flow. That is all they do, and they prevent water from reversing flow. They are a weighted check valve with a means of manual opening.
    Most (maybe all) have some method of opening the flow check to allow gravity flow. Turning a screw, moving a lever etc. I have never seen a flow check get stuck closed. Having the screw, lever or opening mechanism rust up is fairly common in some designs.
    Its would be unusual to get convection flow in radiators below the boiler in the basement
    Hot buoyant water goes up the cooler water drops
    If the basement piping is below to top of the boiler that usually  as a thermal trap. You would need some forced circulation to get flow
  • spudtu
    @hot_rod
    That is a good point, thank you. The basement radiators are on the other side of the house from the boiler and down at basement floor level. Most of the piping to get over there and back is run at the basement ceiling (so above the boiler). But the piping drops down to floor level for the radiator section. That is the section where the radiator pipe burst last year. The basement floor is above grade in that area.
