Title
Dashilongo
Member Posts: 3
Body
Did they tune the burner and do a combustion test? Or is the "airplane noise" coming from the pipes and circulator?. Can you post pictures0
If it only happens when it feeds the water tank I would suspect the dhw circulator (or valve). Sounds like a vibration to me.0
