Propane gas line
csctex
Member Posts: 1
Installing propane gas range and oven. Probably 16000 to 20000 btu. What size gas line do I need. 25 feet approximately
The LP Gas company would use 1/2" OD Copper. I prefer the Black Steel Pipe, But if you need custom cut pipe lengths, and don't have a threader or Mega-Press, You can use the K-copper or L-copper. Stay away from M-Copper for LP gas
Also use the thick wall forged Flare nuts.
Stay away from The thin wall Flare nuts usually found at big box stores
And make sure the copper tubing is properly reamed and prepared before you flare the tubing.
2 -
seems like awfully low btu's for a full propane range with oven0
Yes, a typical slide in gas range is 60,000 btu/hr.
I'd use 1/2" soft copper.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
propane line is also dependent on where it is going to be run and if its going to get closed in after.0
Do you have a 2 stage regulator in the system?0
Home Depot will cut and thread the black iron pipe for free if you buy their pipe.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
