Propane gas line
csctex
csctex Member Posts: 1
Installing propane gas range and oven. Probably 16000 to 20000 btu. What size gas line do I need. 25 feet approximately
  • kcopp
    kcopp Member Posts: 4,663
    1/2" black steel will do fine.
    HomerJSmith
    EdTheHeaterMan Member Posts: 11,989
    The LP Gas company would use 1/2" OD Copper. I prefer the Black Steel Pipe, But if you need custom cut pipe lengths, and don't have a threader or Mega-Press, You can use the K-copper or L-copper. Stay away from M-Copper for LP gas
    Also use the thick wall forged Flare nuts.
    Stay away from The thin wall Flare nuts usually found at big box stores
    And make sure the copper tubing is properly reamed and prepared before you flare the tubing.
    vhaukPC7060
  • yellowdog
    yellowdog Member Posts: 293
    seems like awfully low btu's for a full propane range with oven
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Yes, a typical slide in gas range is 60,000 btu/hr.
    I'd use 1/2" soft copper.
  • yellowdog
    propane line is also dependent on where it is going to be run and if its going to get closed in after.
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,827
    Put it in before gas stoves are outlawed.
    urbngasoutfitrSolid_Fuel_Man
  • JUGHNE
    JUGHNE Member Posts: 11,542
    Do you have a 2 stage regulator in the system?
  • HomerJSmith
    HomerJSmith Member Posts: 2,771
    Home Depot will cut and thread the black iron pipe for free if you buy their pipe.
