In floor solenoid water valve failed?
gtboss
Member Posts: 2
I have a 10 year old hot water HYDRO-AIR 4 zone heat system. 3 of the zones have radiators with small 120v fans and are working fine. #4 is in the master bathroom only, under a stone tile floor that is not getting warm. I switched a 150 watt light bulb on/off to test the thermostat. The load for the thermostat is a 120 vac 70 ohm water valve under the floor tile? or behind the baseboard? which I believe has died. The pipe for the floor heater is 5/8 inch od transparent flexible plastic. Do you agree or am I missing something else? If not, what solenoid water valve would be best to replace it? Thankyou.
What makes you think it is 120v? Most hvac controls are 24vac. Things that would be 120v usually would only be an installed electric heater, electric radiant heat, or maybe a heat lamp or heater in a bath light fixture.0
Thanks for the help. I'll start with the baseboard this weekend.
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
