Picture from underneath boiler, is this normal
melo
melo Member Posts: 96
Is this normal? Please see the pictures taken this morning. I live in the northeast so it’s somewhat cold nowadays. Noticed, the boiler feeding more water lately so I was looking around to make sure nothing was leaking.
I did not notice any leaks when I overfilled the boiler and waited. However, I did capture these pictures and it looks like it can be wet or it can be like that by design/usage throughout the years.
Crown boiler, not sure how old but I would say around 10 years or a little more.
Thoughts?
    EBEBRATT-Ed Member Posts: 20,051
    I think your ok. Although the CI looks a little wet (strange picture and 1 is not clear) the sheet metal and insulation looks clean and it would be stained or rusty if you had a leak
