Radiator piping good or bad?
knkreb
knkreb Member Posts: 13
I was working in a 1930s theater (old grand movie house.). It is heated with steam. I noticed this piping on the upstairs lobby radiator. This doesn't look right unless there's some magic I don't know about. Check out the pictures.
  • Danny Scully
    Danny Scully Member Posts: 1,465
    That’s the supply and return of the same radiator? Yea, no magic, just stupidity 🤣. If I had to guess, that’s not the original radiator and someone made a poor retrofit…
  • ScottSecor
    ScottSecor Member Posts: 1,026
    Assuming the thermostat valve is on the steam supply, the supply pipe may be ok.  However,  the return side will likely never work properly.   Condensate struggles to go uphill, especially if TRV is actually working and set properly.   Keep in mind if it's a vacuum system it might work.
  • bburd
    bburd Member Posts: 1,293
    How well does it heat?
    Bburd
  • How could it ever heat? Steam would never get to the radiator.
    That looks more like hot water.
    bburd
  • Big Ed_4
    Big Ed_4 Member Posts: 3,497
    edited December 2022
    Looks like a couple of off-sets . If you can't go right in, you go around . More important is the return. The system was added after the building was built , normal in the early 1900's . The pipe bend came in handy threading iron pipe . A vice tripod , has the section built in to it for bending pipe . We have it easy today
