Connecting Indirect Water Heater to Buderus GB142
Gbloom
Member Posts: 3
My Buderus LT200 coil is perforated and I need a new water heater. Because the boiler is in crawl space, the LT200 worked out great as it is horizontal. Are there other brands of indirects that work with the Buderus temperature sensor on the GB142?
I did find a place that has a LT200 about three hours away, but also don't want another unit that failels this way.
Thanks,
Gene
Thanks,
Gene
Any well in a water heater can accept the Buderus sensor. Crown Boiler had a horizontal tank that I would place a boiler on top of the tank to conserve space. I don't think the make it anymore. They may have New old stock. would you like me to check?
Thank you! No need look.EdTheHeaterMan said:Any well in a water heater can accept the Buderus sensor. Crown Boiler had a horizontal tank that I would place a boiler on top of the tank to conserve space. I don't think the make it anymore. They may have New old stock. would you like me to check?0
