Offset black pipe suggestions - they wont match up
Subdural
Member Posts: 35
Running black pipe (2") - and need to go up 10 inches and laterally 16 inches - this is not a strait 90 degree fit, I will need to do something else - but I want to know what is the best option for creating an offset of about 1/2 to 1 inch? (add in 45s?) - I just didnt want to create a monster
Got a picture of the space? Are you using threaded or press fitting? Seems like 10” and 16” is plenty of room. Are you dealing with obstructions?
Option 1: Use MegaPress fittings. You can cut the pipe to correct length to match up the pipe and press fitting geometry.You may be able to rent a Ridgid Press tool or contact someone in the trade.Option 2: Are you altering an existing system? Can you unthread and replace the longer pipe section with shorter section with room for union and 90?0
Post a couple pictures so we can get better idea.0
@subdural, could you tell us what application this piping arrangement is on, what pressure and temperatures are involved?
Another arrangement to consider is to cut off the end of the vertical and then use a 2" compression type (Dresser) elbow. Hopefully the horizontal is threaded so only a coupling and nipple would be needed to complete the connection.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
@EdTheHeaterMan i think that will work with the 2 unions! Piping is 2 inch black for steam @Pumpguy, i do not think high pressures. @EdTheHeaterMan (i see you are also a blender guy).0
Not at all, that is your graphic pasted onto a simple Paintbrush program (PaintS for Mac). Then I draw lines to illustrate my concept on drawings you are already familiar with.Subdural said:@EdTheHeaterMan (i see you are also a blender guy).
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
