Less Noisy Vent Fan for Buderus G124X-32???
CaptainKirk777___
Member Posts: 1
Dear Heating Helper Friends,
I own a Buderus G124X-32/5II propane-fired boiler (132k btu) that heats an Ergomax E-65 indirect hot water heater for both DHW and hydronic radiant floor heating. The Buderus has just backed up an outdoor wood-fired boiler for years, but now that I'm getting to be an old man I'd like to stop cutting/loading wood and switch to propane full-time for both DHW and space heating.
The Buderus is located in the basement directly under my bedroom and I find the noise from the exhaust vent fan to be excessive -- especially on start-up. The Buderus was installed in 2000 and has a fan made by Jakel Industries Model #117784-01. The fan feeds exhaust horizontally into a 3" stainless pipe that turns vertical for about 4' before exiting horizontally out the concrete basement wall.
I'm wondering if anyone can recommend a manufacturer known for making extremely quiet exhaust fans for boilers that may make one that could replace the Jakel on my Buderus?
Thanks very much.
Bob
Thanks very much.
Bob
Bob, did you ever get a answer. I have the same blower and am looking for a replacement.0
- 117 Geothermal
