Pressure screw Beckett clean cut
steve144
Member Posts: 1
in Oil Heating
I was just wondering, if you bottom out the pressure screw,approximately how many turns out to get to 100 ,I accidentally turned trying to bleed pump,I know I wasnt supposed to touch it,by mistake,it has flathead screw not Allen screw,I would think most would be the same,all the pictures show in same position,4 ,5 turns out
As said above you need a pressure gauge: https://www.amazon.com/gp/product/B014JOT4VS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
You should check your boiler tag or manual to see what the pressure should be. 100 psi is not common today.
Or better yet...don't touch it.DJD775 said:As said above you need a pressure gauge: https://www.amazon.com/gp/product/B014JOT4VS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Considering that it's now completely unknown what pressure it's set to, thats probably into the "dont run it" territory.STEVEusaPA said:
Currently in building maintenance.0 -
You should check your boiler tag or manual to see what the pressure should be. 100 psi is not common today.0 -
You need an oil burner tech now. You don't kw what pressure the tech set the burner up at or how they might have had to weak it from their initial guess.0
