Best Thermostat for Radiant Slab Floors
BigRob
Member Posts: 332
Happy Thanksgiving!
I've been pretty unsatisfied with my Nest E and the new EcoBee Premium controlling my hydronic slab. Lot's of over heating on sunny days. The Nest radiant feature doesn't seem to do much and the Ecobee may not be much better, even with the remote sensors.
Is there a solid, internet connected, radiant floor focused thermostat out there?
I was not smart enough to add a slab sensor during my last remodel. Nest and Ecobee should offer a remote slab sensor and the logic to interpret it!
You are correct that being able to sense or know the actual slab surface temperature can add more controllability. Slabs can be unruly as they are high mass and don’t respond quickly. South facing slabs with lots of solar gain can be a bear to control
Ecobee had some weather responsive features where it monitored incoming weather/ temperature in an attempt to anticipate and begin the ramp up or down. I don’t know how successfully that function was?Bob "hot rod" Rohr
Their tech support just said to make sure the Ecobee is in "boiler" mode as there is some residual heating compensation in that mode. I'll let it learn and feedback in a month. I like the ecobee premium a lot more than the Nest E, anyway.
I mentioned to Ecobee support to make a "floor" mode for their existing sensors or create a new housing that could be placed on a floor. Seems like a good way to address a decent high-end market. I would pay ~$100 for a floor sensor. I also tweeted them. : ) Anybody know a product person at Ecobee?0 -
I will put a remote on the floor and play around and see how the averaging between all three of my sensors works out. The main display sensor has some compensation adjustment, so maybe I can get it to react correctly and have an accurate temp display.0
We too have no slab sensor, but after much study and information given here, decided to use a Honeywell round mercury switch thermostat, with the advice to set it and forget it, we have been using it for about 5 years now and are completely satisfied. Our home has huge thermal mass so is a little unusual in that.
In the fall we gradually raise the setting about 1/2 a degree at a time, (reverse in the spring. In summer we turn off the boiler, and in winter we leave it set at around 72F. Very rarely we get a temperature overrun and simply open a window or two to control it. We were a little concerned because as we opened the package we saw that we had a Nest box, but opened the box to find a new unused Honeywell with the plastic tabs still in place. I think perhaps the vendor was pranking us we had a chuckle.1 -
tekmar 519 comes with the slab sensor. I’ve used them and like them.Steve Minnich0
I've been using the Tekmar 561 since my last post. At first, without a slab sensor, it reduced the error to set point quite a bit. The PWM damped out a lot of overshoot. I've since wired up a crudely installed floor sensor and that really dialed it in.
The wifi control is basic, but all you really need. More charts and historical data that updates on the hour would be nice. Full app control of settings would also be a good addition.
2
