Article Sharing: Cold Climate Heat Pump Challenge
DJDrew
DJDrew Member Posts: 107
Anyone hear of this "Cold Climate Heat Pump Challenge"? Looks pretty cool. The biggest issue with most heat pumps is the efficiency ratio at low outdoor temps.
https://www.pv-magazine.com/2022/11/03/air-source-heat-pump-for-harsh-cold-climates/
Hot_water_fanIn_New_England
    hot_rod Member Posts: 27,425
    Hard to pull a lot of heat from -20°F air! Amazing it works at all. I suppose any COP above 1 is still beating electric resistance.
    Some of the ccA2WHP controls keep the HP running and bring on a boiler or other backup source. Use the HP as long as it is more cost effective than the backup source.
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,241
    Very interesting - but Mitsubishi and others already have heat pumps that work to the negative Fahrenheit teens, so these gains are marginal.  I wonder about how useful this is - should be extremely helpful for the grid, but who cares about that when they’re buying one? Maybe the utilities will pay for it? Or would a propane furnace backup be cheaper?
    I think the goal is to get efficiency up when under those severe operating conditions
    we know 180F is possible , and sub zero operation. Now getting it all together, high temperature, low ambient, and highest COP
    It will happen at some point, lots of R&D going into the challange.
    DJDrew
  • fentonc
    fentonc Member Posts: 340
    Here are the requirements they're trying to meet: https://www.energy.gov/sites/default/files/2022-02/bto-cchp-fact-sheet-021822.pdf
    The main target seems to be 100% capacity and a COP of 2.1-2.4 at 5F using a refrigerant with a GWP of less than 750 (so R-32 is okay, R-410a is not). I bet Mitsubishi and some others might already meet this target, but from the DOE's perspective, the more the merrier. I think anything with that performance would have cheaper operating costs than natural gas here in ConEd territory.
    DJDrew
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    Wow, -15f (-26c) is starting to get near my design temp.
    I could manage to live with strip heating when it's below that, not a huge amount of the season.
    Alas, if it burns up the compressor just after the warranty period ends...
    Still, good to see they're making targets like that.
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,981
    I found this study done by the government a few years ago. It showed substantially lower heating costs with gas than a heat pump. It was for cold climates. I found it interesting
    https://nrel.gov/docs/fy15osti/63913.pdf
    Ray Wohlfarth
    Boiler Lessons
    Air to air mini splits, or air to water units?
  • Hot_water_fan
    Today's gas prices have ended that :D
    DJDrew
  • RayWohlfarth
    @hot_rod air to air
    @Hot_water_fan Like I said it was a few years ago LOL
    Ray Wohlfarth
    Boiler Lessons
