Username and Password for IBC VX 150 Web interface
ChrisWilliams2
Member Posts: 31
I was unable to find the default username and password for the network interface on the IBC VX150 boiler. Maybe it's on the device somewhere, if anyone could let me know I would appreciate it.
Hello @ChrisWilliams2,
Maybe try this, otherwise you may have to go through an online registration process or Tech Support.
https://www.ibcboiler.com/support/TIPortal/Content/Guides_and_manuals/VX/VX_series_PDFs.htm
https://www.ibcboiler.com/support/TIPortal/Content/Guides_and_manuals/V10_controller/Enhanced_UI/V-10_controller.pdf
https://www.ibcboiler.com/support/TIPortal/Content/Guides_and_manuals/V10_portal/IBC Portal.pdf
https://www.ibcboiler.com/support/TIPortal/Content/IBC_V10_Portal/Getting_connected_to_the_IBC_V10_portal.htmNational - U.S. Gas Boiler 45+ Years Old
One Pipe System0 -
Thank you, they work fine on the system itself but not the web. I will try to give them a call. Thank0
Hello @ChrisWilliams2, Is the network interface you are referring to a separate box not supplied by the boiler's manufacture, like a cable modem ?National - U.S. Gas Boiler 45+ Years Old
One Pipe System0
- 117 Geothermal
