Is there any difference on these surface igniters
Flannyman7
Member Posts: 1
511-330-148 (wire connector) vs 511-330-188 (wire leads)
yeah, ones an oem (511-330-148) and is beefier and one is an aftermarket (511-330-188) which is thinner. The oem will just plug right back in. The aftermarket might require you to cut the molex plug off and splice it together.0
about $100.00
other than that, not much. They both fit in the same hole on the boiler. they both will light the gas,
they both will fail over time. I would go with the lower cost. You can have 4 fail and still be ahead of the game.Edward Young Retired
- 117 Geothermal
