Taco control panel lights
TD101112
Member Posts: 1
in Oil Heating
The valve (red) light on my taco control panel for an oil fired boiler does not seem to be coming on. The system is pumping out heat to that particular zone but the light is not going on. Is it normal for a light to burn out? This is a 10-15 yr old system and the light that won’t turn on is for the most used zone. All the other zone lights works normally.
