Open coil questions
Progen
Member Posts: 2
The next frame and heating chamber for my home built coffee roaster has not been built yet but which will have better coil to air heat transfer?
Smaller and closer coils or larger and further ones? That's assuming I'm using the same length and gauge of nichrome.
Also, I couldn't find bushings of the size I wanted so I made around 80 of these from 25mm OD 15mm ID tubes. The intended gauge will be 1.2mm. Will I have hot spots because there'll be 3 per column and I'm thinking of a 2 x 8 array to give me around 10kW.
That means a total of 48 of these bushings quite close to each other in a tall narrow chamber.
All this to roast coffee?
I wish I had the free time that you seem to have.0 -
Mattmia, but I noticed a lot of open coil manufacturers tend to coil with smaller diameter and have more coils instead of larger ones. Why is that?
I even saw a large open coil array that was like 2/3 the size of a single bed with perhaps only 20mm ID coils.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
