Arco Cast Iron Convectors - American Standard - water pressure limit
Bijan
Bijan Member Posts: 1
Can anyone tell me what the highest limit is for water pressure in these units?
    Steamhead Member Posts: 18,453
    30 PSI- which is when the boiler's safety valve should blow. Normally they run less than that, depending on the height of the building.
    Consulting
