GA124 low temp setting
CGeorge
CGeorge Member Posts: 4
We have a GA124 I just installed in our house. Question is where to set the low temp setting ? Its a baseboard heating system set at a high limit of 180. It seems like cold start vs hot start there isnt a very clear answer. Thank you
    mattmia2 Member Posts: 16,058
    Usually you only want hot start if you are running a tankless coil for domestic hot water.
    EdTheHeaterMan Member Posts: 11,769
    There is no "Low Limit" on that Buderus boiler, so there is no need to set it! But if you find one on there, Do let us know about it.
