Radiant above uninsulated slab
baltik
Member Posts: 21
What's the best way to add radiant over uninsulated slab, I am in a moderate climate but am sensitive to build up height (the area has low ceilings already).
My current thinking is:
1" of foam panel above the slab, using an adhesive
attach pex to the foam panel
pour 1.5" gypcrete
floating engineered wood floor above
alternatively:
plywood glued on top with routed grooves for pex
optional: aluminum transfer panels
nailed engineered wood floor on top
would love to hear some feedback or alternatives
some approximate examples of these setups I've found:
pour 1.5" gypcrete
alternatively:
It comes down to how much insulation value you want for the system. 2” would be nice, 1/2” bare minimum.Radiant ceilings typically only add 1/2” for another option, same radiant feel, much less install hassle. Then engineered floor over 1/4” foam for some thermal break.
Is it slab on grade, or a basement? Adding more than 1/2” on a basement floor should involve a stair case rebuild, as the lower step will be a trip and fall hazard. I think code allows 3/8” difference maximumBob "hot rod" Rohr
Appreciate that - always a wealth of knowledge!
it is slab on grade and stairs haven’t been constructed, so not concerned about that. My preference is to do floor radiant vs ceiling as the ceiling has many structural beams to work around.
in the above scenarios is there any concern with using adhesive to attach insulation? I presume I should incorporate some sort of moisture barrier as well? What would be the best way to go about that?0 -
While not a very thick insulation, I like the Roth Radiant panels. They only add 1/2- 5/8 and have a nice aluminum top layer. 6 or 12” spacing. Walk the tube in and float the wood right over it. Gets you a nice, quick responding system.Tube it at 6” spacing for great surface temperature consistency.
I use foam adhesive with a notched trowel to glue it down. If the floor is wavy put some weight on the panels
You could seal the floor first if radon gas is a concern. The glue with a notched trowel does not seal the entire floor. Any of the poly floor sealers with a roller should work.
It MUST be foam adhesive, regular construction adhesive will dissolve the foams. Find it in one or five gallon bucketsBob "hot rod" Rohr
@psb75 good idea, Radon testing is included in most real estate contracts now. A good idea to test before you start covering the slab. It usually an easy fix, looks like a 4" dryer vent and blower piped to the outdoors. There are companies that specialize in that work, often a 1 day job.
Realtors have these companies on speed dial, as it makes or breaks a sale!Bob "hot rod" Rohr
You got that right Bob!
Radon re-mediators leave a visible water-column gauge inside the house, on the vent pipe to show vacuum.0 -
I've never heard of Radon in our area, so thankfully not a factor. I'm still a but fuzzy on where to integrate the moisture barrier, the concern is that the adhesive wouldn't have much hold then...
https://county-radon.info/CA/Marin.html0 -
A sealer like this, penetrates and should still allow you to mastic or adhesive over it? Check with the manufacturerBob "hot rod" Rohr
Living the hydronic dream1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
